Rowe RI-3 Verstärker 15.05.12 07:52 |
Registriert - Registered: 12 Jahre - Years Einträge - Posts: 9 |
bei dem Verstärker meiner RI-3 ist eines der beiden Hochton Schutz Lämpchen defekt, gegen welche Lampe kann ich diese ersetzen?
2. Frage:
Die Treble und Bass Schalter auf dem Verstärker funktionieren nicht mehr (mit unter nur sehr gering).
Sind dort die Kondensatoren auf der Vorverstärker Platine nichts mehr Wert?
Johannes
2. Frage:
Johannes
Re: Rowe RI-3 Verstärker 15.05.12 11:06 |
Hello John,
Are you asking for advice on this amplifier and pre-amplifier or are you looking for parts to repair it?
Regards
Alan
Alan Hood
ami-man
UK
Regards
Alan
Alan Hood
ami-man
UK
Re: Rowe RI-3 Verstärker 17.05.12 18:34 |
Re: Rowe RI-3 Verstärker 18.05.12 14:13 |
Hello John,
Can you please let us have the Rowe Ami amplifier model number the orgiginal in the RI-3 would not have pre-amp lamps so the amplifier could be the later type out of a RI-5 orthe 125 or 130 watt type.
Regards
Alan
Alan Hood
ami-man
UK
Regards
Alan
Alan Hood
ami-man
UK
Re: Rowe RI-3 Verstärker 18.05.12 14:48 |
Hi,
the Pre Amp is Rowe 6-08552-01
The Amp seems to be the 125 Watt Modell.
Re: Rowe RI-3 Verstärker 21.05.12 09:53 |
Hello John,
The main issues on this pre-amplifier are dry joints on the 13 pin molex jumper plug connection and the two 4 pin connection that connect to the driver boards.
The two lamps tend to rot or break off from the board, the result is that you loose that channel. If the board is stored in damp conditions the bass & treble switches may need to be removed from the board so they can be striped down and cleaned (if corroded they need to be replaced, check on inspection).
If you require any parts for the pre-amp contact me off of line.
Regards
Alan
Alan Hood
ami-man
UK
Regards
Alan
Alan Hood
ami-man
UK
