Princess 1493 28.03.12 17:04 |
Registriert - Registered: 12 Jahre - Years Einträge - Posts: 24 |
Hi,
Sometimes with dinked records the record seems to not be placed on the deck centrally causing obvious playback problems. It does do this all the time but wondered if anyone has had this problem.
Thanks.
Thanks.
Re: Princess 1493 01.04.12 21:15 |
"Dinked records" – does this mean the centre hole was enlarged?
If so is the large hole centered, too small, too large?
Regarding your description – is this happen all the time or only sometimes?
Hildegard
Hildegard
Re: Princess 1493 02.04.12 11:44 |
Hi,
It only happens occasionally and with 1 or 2 same records. I think the hole is either wrong size or misaligned.
Thanks.
Neil
Thanks.
Neil
Re: Princess 1493 02.04.12 11:52 |
Hello Neil,
if the centre hole is misaligned or too large I guess these records sound cranky as well.
If the hole is too small the record does not fit the centre hub and cannot be played (well).
Kind regards - Hildegard
