ROCK OLA 432 220V VALVE AMP
geschrieben von - posted by nickstuart
21.03.12 11:59
Hi, is it ok to use the 42845-A valve amp in the 220v european version of the 432 GP160 jukebox? Would it need modifying and are there any other valve amps that would directly fit?
Thanks, Nick.
Cle
Re: ROCK OLA 432 220V VALVE AMP
23.03.12 09:32
Hello Nick,
the 42845-A is, according to my Parts Manual the correct Amp for the 432, so yes, if this one doesn't fit directly, I don't know which one will.
If your question is, if there is a difference beween the Amp in the US Version, and in the European Version of the 432, then the answer is: No, the same Amp is used, only the Power Supply is different. Even the Flurocent Lamps are, to my knowledge, supplied with 110 V out of the Power Supply.
Regards
Clemens
