Laut starke problem. 21.12.11 22:12 |
Registriert - Registered: 13 Jahre - Years Einträge - Posts: 56 |
Hallo.
Ich habe eine frage .
DIe lautstarke von eine jupiter super s104 is nicht io
Dem verstarker ist revisiert . Ich habe die spannungen kontroliert und im ruhe mess ich die hochspannung 48 v (muss 45 v sein)
Im operating mess ich 264 v (muss sein 375 v) . Kann das eine ursache sein fur dem fehler.
Excuse me for my bad german.
grusse Leon
grusse Leon
Re: Laut starke problem. 22.12.11 10:35 |
Hello Leon
The fault is to search inside the amplifier, although it has already been revised. The too small voltage is not the cause but the result of the defect. The amplifier should again be repaired by a professional.
Best regards - charly49
Re: Laut starke problem. 22.12.11 11:47 |
Hello Charly,
Thank you for replying
Maybe i am not clear enough , but the voltage measured inside the power supply . The wire that is in use for the high voltage.
Maybe its a bad capacitor on the power supply. I will check that first .
Kind regards . Leon
Kind regards . Leon
Re: Laut starke problem. 22.12.11 16:17 |
Hello Leon,
in general the cartridge can be faulty, too, which results usually in no resp. less volume.
Maybe you can hook the cartridge to another working amplifier to be more sure where the fault is located.
Kind regards - Hildegard Stamann
Re: Laut starke problem. 20.01.12 11:43 |
Hello All.
The problem was a wrong cartridge . Magnetic instead of ceramic.. How simple live can be .
The amp was in perfect condition, even i was not shure about it .
In the power supply was also a bad condensor .
But he is playing like hell again...
Thanks
kind regards Leon
Thanks
kind regards Leon
Re: Laut starke problem. 20.01.12 16:49 |
Thank you for letting us know, Leon.
I'm glad your Jupiter s104 plays and sounds well again.
like hell again >>> I hope your neigbours love your music, too!
